The Improved DBSCAN Algorithm Study on Maize Purity Identification
In order to identify maize purity rapidly and efficiently, the image processing technology and clustering algorithm were studied and explored in depth focused on the maize seed and characteristics of the seed images. An improved DBSCAN on the basis of farthest first traversal algorithm (FFT) adapting to maize seeds purity identification was proposed in the paper. The color features parameters of the RGB, HIS and Lab color models of maize crown core area were extracted, while H, S and B as to be the effective characteristic vector after data analysis. The abnormal points of different density characteristic vector points were separated by FFT. Then clustering results were combined after local density cluster by DBSCAN. According to the result of test, the method plays a great role in improving the accuracy of maize purity identification.
Informatique [cs]
