Abstract : In order to create the simulation model of Above-ground Organs Morphogenesis of Flue-cured Tobacco, the dynamic model of organ morphology in different growing step of tobacco was built with potting experimental methods with which the biomass of tobacco organ in different growth period can be systematically determined. As simulation of organ morphology of tobacco measured in 2007 shows that the correlation coefficient between the simulated value and the measured value of above-ground organ of tobacco in different growth cycle is 0.735 to 0.9997 at significant level which proved that the dynamic of above-ground organ morphogenesis of tobacco can be predicted well by the model. The regulation of growth of tobacco morphology can be reflected well by the model of above-ground organ morphogenesis; furthermore, the model can also be a theoretical basis for virtual growth of tobacco.
Daoliang Li; Yingyi Chen. 5th Computer and Computing Technologies in Agriculture (CCTA), Oct 2011, Beijing, China. Springer, IFIP Advances in Information and Communication Technology, AICT-370 (Part III), pp.217-229, 2012, Computer and Computing Technologies in Agriculture V. 〈10.1007/978-3-642-27275-2_24〉
https://hal.inria.fr/hal-01361141
Contributeur : Hal Ifip
Soumis le : mardi 6 septembre 2016 - 17:07:56
Dernière modification le : mardi 6 septembre 2016 - 17:40:17
Document(s) archivé(s) le : mercredi 7 décembre 2016 - 14:01:37
Shuping Xiong, Lei Xi, Jucai Wang, Guanghui Xu, Xinming Ma. Research on the Simulation Model of Above-Ground Organs Morphogenesis of Flue-Cured Tobacco. Daoliang Li; Yingyi Chen. 5th Computer and Computing Technologies in Agriculture (CCTA), Oct 2011, Beijing, China. Springer, IFIP Advances in Information and Communication Technology, AICT-370 (Part III), pp.217-229, 2012, Computer and Computing Technologies in Agriculture V. 〈10.1007/978-3-642-27275-2_24〉. 〈hal-01361141〉
