Improvement of the Capacitive Grain Moisture Sensor - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Liu Yang
  • Fonction : Auteur
  • PersonId : 972250
Yongjun Zheng
  • Fonction : Auteur
  • PersonId : 987346
Zhijun Ren
  • Fonction : Auteur
  • PersonId : 986564
Moisture is one of the most important factors affecting grain quality in storage. The grain must be dried as soon as possible after harvesting to lower moisture to a standard level. It is difficult to obtain satisfactory measurement effect on precision in capacitive grain’s moisture measurement due to many influencing factors, such as temperature, species and weight. The data confusion method of Radial Basis Function nerve network is adopted with improved hardware of the measurement system. Tests show that the precision in moisture measurement of wheat has been improved.
978-3-642-27275-2_34_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01361152 , version 1 (06-09-2016)
Paternité
Liu Yang, Yongjun Zheng, Zhijie Jiang, Zhijun Ren. Improvement of the Capacitive Grain Moisture Sensor. 5th Computer and Computing Technologies in Agriculture (CCTA), Oct 2011, Beijing, China. pp.300-307, ⟨10.1007/978-3-642-27275-2_34⟩. ⟨hal-01361152⟩
68 Consultations
95 Téléchargements
