MCC’2015 – The Fifth Model Checking Contest - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue LNCS Transactions on Petri Nets and Other Models of Concurrency Année : 2016
The Model Checking Contest (MCC) is an annual competition between software tools that verify concurrent systems using state-space exploration techniques, either explicit-state or symbolic. The present article provides a comprehensive account of the 2015 edition of the MCC. The principles of the contest are described, together with its underlying software infrastructure. The tools that competed in 2015 are listed and the results of the contest are summarized.
main.pdf (156.63 Ko) Télécharger le fichier
hal-01361274 , version 1 (07-09-2016)
Paternité
Fabrice Kordon, Hubert Garavel, Lom Messan Hillah, Emmanuel Paviot-Adet, Loïg Jezequel, et al.. MCC’2015 – The Fifth Model Checking Contest. LNCS Transactions on Petri Nets and Other Models of Concurrency, 2016, Lecture Notes in Computer Science, 9930, pp.262-273. ⟨10.1007/978-3-662-53401-4_12⟩. ⟨hal-01361274⟩
633 Consultations
260 Téléchargements
