Energy Consumption Analysis of Software Polar Decoders on Low Power Processors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a new dynamic and fully generic implementation of a Successive Cancellation (SC) decoder (multi-precision support and intra-/inter-frame strategy support). This fully generic SC decoder is used to perform comparisons of the different configurations in terms of throughput, latency and energy consumption. A special emphasis is given on the energy consumption on low power embedded processors for software defined radio (SDR) systems. A N=4096 code length, rate 1/2 software SC decoder consumes only 14 nJ per bit on an ARM Cortex-A57 core, while achieving 65 Mbps. Some design guidelines are given in order to adapt the configuration to the application context.
article.pdf (410.2 Ko) Télécharger le fichier
hal-01363975 , version 1 (15-11-2016)
Adrien Cassagne, Olivier Aumage, Camille Leroux, Denis Barthou, Bertrand Le Gal. Energy Consumption Analysis of Software Polar Decoders on Low Power Processors. The 24nd European Signal Processing Conference (EUSIPCO 2016), Aug 2016, Budapest, Hungary. ⟨10.1109/EUSIPCO.2016.7760327⟩. ⟨hal-01363975⟩
253 Consultations
320 Téléchargements
