Abstract : The purpose of this paper is to present and discuss a general HV topology of the solid-state Marx modulator, for unipolar or bipolar generation connected with a step-up transformer to increase the output voltage applied to a resistive load. Due to the use of an output transformer, discussion about the reset of the transformer is made to guarantee zero average voltage applied to the primary. It is also discussed the transformer magnetizing energy recovering back to the energy storage capacitors. Simulation results for a circuit that generates 100 kV pulses using 1000 V semiconductors are presented and discussed regarding the voltage and current stress on the semiconductors and result obtained.
https://hal.inria.fr/hal-01365751 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, September 13, 2016 - 3:53:49 PM Last modification on : Wednesday, October 14, 2020 - 8:32:03 PM Long-term archiving on: : Wednesday, December 14, 2016 - 2:05:09 PM
H. Canacsinh, José Silva, Sónia Pinto, Luis Redondo, João Santana. Solid-State Bipolar Marx Converter with Output Transformer and Energy Recovery. 3rd Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2012, Costa de Caparica, Portugal. pp.403-410, ⟨10.1007/978-3-642-28255-3_44⟩. ⟨hal-01365751⟩
