A Utility-Based Reputation Model for the Internet of Things - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Benjamin Aziz
  • Fonction : Auteur
  • PersonId : 989246
Paul Fremantle
  • Fonction : Auteur
  • PersonId : 989247
Rui Wei
  • Fonction : Auteur
  • PersonId : 989248
Alvaro Arenas
  • Fonction : Auteur
  • PersonId : 989249
The MQTT protocol has emerged over the past decade as a key protocol for a number of low power and lightweight communication scenarios including machine-to-machine and the Internet of Things. In this paper we develop a utility-based reputation model for MQTT, where we can assign a reputation score to participants in a network based on monitoring their behaviour. We mathematically define the reputation model using utility functions on participants based on the expected and perceived behaviour of MQTT clients and servers. We define an architecture for this model, and discuss how this architecture can be implemented using existing MQTT open source tools, and we demonstrate how experimental results obtained from simulating the architecture compare with the expected outcome of the theoretical reputation model.
421518_1_En_18_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01369560 , version 1 (21-09-2016)
Paternité
Benjamin Aziz, Paul Fremantle, Rui Wei, Alvaro Arenas. A Utility-Based Reputation Model for the Internet of Things. 31st IFIP International Information Security and Privacy Conference (SEC), May 2016, Ghent, Belgium. pp.261-275, ⟨10.1007/978-3-319-33630-5_18⟩. ⟨hal-01369560⟩
75 Consultations
102 Téléchargements
