Porting the Distem Emulator to the CloudLab and Chameleon testbeds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2016
The Distem emulator was designed in the context of the Grid'5000 testbed. In this paper, we describe the experience of porting Distem to two testbeds: CloudLab and Chameleon, in order to uncover possible issues when deploying Distem on platforms different from Grid'5000. It also provides some insight on differences between the design of each of those three testbeds, and their impact on experimenters.
RR-8955.pdf (506.94 Ko) Télécharger le fichier
hal-01372050 , version 1 (26-09-2016)
  • HAL Id : hal-01372050 , version 1
Cristian Ruiz, Emmanuel Jeanvoine, Lucas Nussbaum. Porting the Distem Emulator to the CloudLab and Chameleon testbeds. [Research Report] RR-8955, Inria. 2016. ⟨hal-01372050⟩
183 Consultations
136 Téléchargements
