Stability of the Kalman filter for continuous time output error systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Systems and Control Letters Année : 2016
The stability of the Kalman filter is usually ensured by the uniform complete controllability regarding the process noise and the uniform complete observability of linear time varying systems. This paper studies the case of continuous time output error systems, in which the process noise is totally absent. The classical stability analysis assuming the controllability regarding the process noise is thus not applicable. It is shown in this paper that the uniform complete observability alone is sufficient to ensure the asymptotic stability of the Kalman filter applied to time varying output error systems, regardless of the stability of the considered systems themselves. The exponential or polynomial convergence of the Kalman filter is then further analyzed for particular cases of stable or unstable output error systems.
Automatique
kalman_SCL_SubmittedMay2016.pdf (314.87 Ko) Télécharger le fichier
hal-01376819 , version 1 (05-10-2016)
Boyi Ni, Qinghua Zhang. Stability of the Kalman filter for continuous time output error systems. Systems and Control Letters, 2016, 94, pp.172 - 180. ⟨10.1016/j.sysconle.2016.06.006⟩. ⟨hal-01376819⟩
154 Consultations
807 Téléchargements
