Comparing BIM in Construction with 3D Modeling in Shipbuilding Industries: Is the Grass Greener on the Other Side? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ran Luming
  • Fonction : Auteur
  • PersonId : 990032
Vishal Singh
  • Fonction : Auteur
  • PersonId : 990033
Building Information Modelling (BIM), as an object-oriented tool, has been the buzzword in Architecture Engineering and Construction (AEC) sector in recent years. The buzz has created a lot of promise of an imminent paradigm shift and productivity and lifecycle improvements in the AEC sector, and plenty of benefits are cited in the literature. Consequently, the word has reached the shipbuilding industry as well, which faces many similar productivity and lifecycle challenges as the AEC industry, and which is seeking similar advancements in digital tools that can bring around the change. As a result, the Finnish shipbuilding industry expressed interest in exploring what are the BIM-enabled best practices in the AEC sector, and which of these can potentially be transferred to the shipbuilding industry. This research explored these issues. Findings suggest that due to lack of mutual communication, the professionals across each industry believe the other to be doing better.
Mots clés
421082_1_En_18_Chapter.pdf (83.34 Ko) Télécharger le fichier
hal-01377443 , version 1 (07-10-2016)
Paternité
Ran Luming, Vishal Singh. Comparing BIM in Construction with 3D Modeling in Shipbuilding Industries: Is the Grass Greener on the Other Side?. 12th IFIP International Conference on Product Lifecycle Management (PLM), Oct 2015, Doha, Qatar. pp.193-202, ⟨10.1007/978-3-319-33111-9_18⟩. ⟨hal-01377443⟩
106 Consultations
241 Téléchargements
