Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, Epiciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : This paper deals with the embodiment design of mechatronic product and is intended for proposing a novel design support framework based on multiobjective optimization approaches. This framework builds design architectures by aggregating solution principles presented within a morphological matrix. Then, the solution principles are analyzed against compatibility. This compatibility analysis results in a design structure matrix. Once this compatibility analysis has been performed, the optimization framework developed in this paper is applied to find combination of solution principles. We showed the application of our framework for the embodiment design of a wind turbine.
https://hal.inria.fr/hal-01377511 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, October 7, 2016 - 10:01:50 AM Last modification on : Thursday, March 5, 2020 - 4:42:04 PM Long-term archiving on: : Friday, February 3, 2017 - 7:08:16 PM
Didier Casner, Rémy Houssin, Jean Renaud, Dominique Knittel. A Multiobjective Optimization Framework for the Embodiment Design of Mechatronic Products Based on Morphological and Design Structure Matrices. 12th IFIP International Conference on Product Lifecycle Management (PLM), Oct 2015, Doha, Qatar. pp.813-825, ⟨10.1007/978-3-319-33111-9_74⟩. ⟨hal-01377511⟩
