Conference papers
Debugging Methods Through Identification of Appropriate Functions for Internal Gates
Abstract : In this chapter, we propose methods for correcting gate-level designs by identifying appropriate logic functions for internal gates. We introduce programmable circuits, such as look up table (LUT) and multiplexer (MUX) to the circuits under debugging, in order to formulate the correction processes mathematically. There are two steps in the proposed methods. The first one is to identify sets of gates and their appropriate inputs whose functions are to be modified. The second one is to actually identify logic functions for the correction by solving QBF (Quantified Boolean Formula) problems with repeated application of SAT solvers. There are a number of bugs which cannot be corrected unless the inputs of the gates to be modified are changed from the original ones, and the selection of such additional inputs is a key for effective debugging. We show a couple of methods by which appropriate inputs to the gates can be efficiently identified. Experimental results for each such a method as well as their combinations targeting benchmark circuits as well as industrial ones are shown.
Document type :
Conference papers
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/hal-01380296
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Wednesday, October 12, 2016 - 5:38:10 PM
Last modification on : Monday, May 17, 2021 - 12:00:04 PM
Long-term archiving on: : Saturday, February 4, 2017 - 8:30:22 PM
File
367527_1_En_1_Chapter.pdf
Identifiers
Citation
Kosuke Oshima, Takeshi Matsumoto, Masahiro Fujita. Debugging Methods Through Identification of Appropriate Functions for Internal Gates. 21th IFIP/IEEE International Conference on Very Large Scale Integration - System on a Chip (VLSI-SoC), Oct 2013, Istanbul, Turkey. pp.1-22, ⟨10.1007/978-3-319-23799-2_1⟩. ⟨hal-01380296⟩
Share
Metrics
Record views
39
Files downloads
124
