Self-similar real trees defined as fixed-points and their geometric properties
We consider fixed-point equations for probability measures charging measured compact metric spaces that naturally yield continuum random trees. On the one hand, we study the existence, the uniqueness of the fixed-points and the convergence of the corresponding iterative schemes. On the other hand, we study the geometric properties of the random measured real trees that are fixed-points, in particular their fractal properties. We obtain bounds on the Minkowski and Hausdorff dimension, that are proved tight in a number of applications, including the very classical continuum random tree, but also for the dual trees of random recursive triangulations of the disk introduced by Curien and Le Gall [Ann Probab, vol. 39, 2011]. The method happens to be especially powerful to treat cases where the natural mass measure on the real tree only provides weak estimates on the Hausdorff dimension.
