Abstract : Various attacks are designed to gain access to the assets of Java
Card Platforms. These attacks use software, hardware or a combination of
both. Manufacturers have improved their countermeasures to protect card as-
sets from these attacks. In this paper, we attempt to gain access to assets of a
recent Java Card Platform by combining various logical attacks. As we did not
have any information about the internal structure of the targeted platform,
we had to execute various attacks and analyze the results. Our investigation
on the targeted Java Card Platform lead us to introduce two generic methods
to gain access to the assets of Java Card Platforms. One of the new methods
we present in this paper is based on the misuse of the Java Card API to build
a type confusion and get access to the objects (including cryptographic keys)
of a Java Card applet. The other method is a new approach to get access to
the return address of the methods in Java Cards with Separate Stack counter-
measure. We also propose a pattern that the targeted platform uses to store
data and code of applets on the card plus the ability to read and write in the
data and code area of the applets in dierent security contexts. These new
attacks occur even in the presence of countermeasures such as Separate Stack
for kernel and user data, indirect mapping for objects addressing and rewall
mechanisms.
