Conference papers
Decomposition Analysis Resolution Process (DAR) of Systems Engineering Applied to Development of Countermeasure on Leakage of Engine Head-Gasket
Abstract : This paper reviews a countermeasure development of leakage from coolant seals of head-gaskets in a diesel engine applying the Decomposition Analysis and Resolution Process (DAR). We can find complexity arising from some causes of leakage even in a simple square-ring rubber seal. The major causes are (1) large displacement around a head-gasket generated by the combustion, (2) seal distortion at a high compression, (3) seal rubber degradation induced by coolant microorganism deterioration, (4) uncontrolled seal production and (5) unsuitable rubber composition. Through our DAR, we can resolve the complexity of the leakage and can clarify all the cause positions and their relationships. We can confirm that an improved silicone rubber seal, which has a higher fatigue strength, an excellent acid-resistance and a uniform contact property, is the correct resolution. This paper also shows development of a hydrogenated nitrile rubber seal as a permanent measure, which can extend the Middle of Life (MOL) of Product Lifecycle Management (PLM) of the industrial diesel engine production.
Document type :
Conference papers
Complete list of metadata
Cited literature [8 references]  Display  Hide  Download
https://hal.inria.fr/hal-01386495
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Monday, October 24, 2016 - 11:27:59 AM
Last modification on : Thursday, March 5, 2020 - 4:42:06 PM
File
978-3-662-45937-9_19_Chapter.p...
Identifiers
Citation
Satoshi Ohkawa, Hidekazu Nishimura, Yoshiaki Ohkami. Decomposition Analysis Resolution Process (DAR) of Systems Engineering Applied to Development of Countermeasure on Leakage of Engine Head-Gasket. 11th IFIP International Conference on Product Lifecycle Management (PLM), Jul 2014, Yokohama, Japan. pp.181-192, ⟨10.1007/978-3-662-45937-9_19⟩. ⟨hal-01386495⟩
Share
Metrics
Record views
137
Files downloads
111
