Negative Side Effects of Lean Management - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper investigates the problem of unplanned negative effects, which may result from implementation of lean management. Using as the basis empirical evidence from European machine tools industry it is argued, that in majority of cases targeted effects (mostly cost savings, production and utilization increase) are followed, with a delay, by negative side effects (mostly unplanned increased costs, quality issues, customer dissatisfaction). It is suggested, that using the controlling framework as management tool may enable to avoid these unlikely effects. Its relevant adoption, to support multi-perspective assessment of lean management implementations is presented within the paper.
978-3-662-44733-8_21_Chapter.pdf (141.91 Ko) Télécharger le fichier
hal-01387177 , version 1 (25-10-2016)
Paternité
Andreas Mueller, Stanisław Strzelczak. Negative Side Effects of Lean Management. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2014, Ajaccio, France. pp.167-174, ⟨10.1007/978-3-662-44733-8_21⟩. ⟨hal-01387177⟩
166 Consultations
1277 Téléchargements
