Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : Mechanical seals are the most diffuse solution for rotating shaft sealing because of their high safety performances and low maintenance costs. The only requirement to meet high service level is a care in the choice of a sealing system suitable for fluids treated and operating conditions. Mechanical seal manufacturers usually have very large catalogues with a wide mix of products for each use and also offers to their clients customized solutions and maintenance service. This could result in high inventory cost for manufacturers which want to guarantee high maintenance service performances. This study shows a reliability driven methodology to reduce the mix and maintain high performances.
https://hal.inria.fr/hal-01387288 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, October 25, 2016 - 1:09:12 PM Last modification on : Friday, September 4, 2020 - 2:24:30 PM
Lucio Compagno, Natalia Trapani. Reliability Driven Standardization of Mechanical Seals for Petrochemical Applications. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2014, Ajaccio, France. pp.455-462, ⟨10.1007/978-3-662-44733-8_57⟩. ⟨hal-01387288⟩
