Paraconsistent Method of Prospective Scenarios (PMPS) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work presents the Paraconsistent Method of Prospective Scenarios (PMPS) in order to support organizations in their strategic planning, being a useful tool, as it serves a noble task. The method is based on non-classical logic, called the Paraconsistent Annotated Evidential Logic Eτ (Logic Eτ), this logic is excelling in the fields of research and it’s main characteristics are set by the thought of experts, generating input parameters and been consolidated by the collective way that translates into mathematical terms. Logic Eτ is not trivial and has the capacity to manipulate imprecise and conflicting information.
978-3-662-44739-0_10_Chapter.pdf (285.32 Ko) Télécharger le fichier
hal-01388211 , version 1 (26-10-2016)
Paternité
Nélio Dos Reis, Cristina De Oliveira, Liliam Sayuri Sakamoto, André De Lira, Jair Minoro Abe. Paraconsistent Method of Prospective Scenarios (PMPS). IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2014, Ajaccio, France. pp.76-84, ⟨10.1007/978-3-662-44739-0_10⟩. ⟨hal-01388211⟩
68 Consultations
103 Téléchargements
