How Information Systems Assist the Management of the Supply Chain in an Emerging Country Like Brazil - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
IT has an important role in the performance of companies, provides a flow of information that makes the supply chain become more robust and resilient, without compromising efficiency. Most companies are applying IT systems, mainly in Supply Chain Management (Supply Chain Management - SCM) to enhance their performance in competitive global markets. The research is important because it will provide a study of what are the IT systems used to manage the supply chain and likely future trends. To achieve the objective of this work was carried out a survey with consultants and professionals in IT and supply chain who work in large companies. To collect the data needed for analysis, we used the exploratory research of a qualitative nature. Thus, we can conclude that the use of IT in the supply chain directly impacts in the areas of planning, manufacturing suppliers, customers and delivery.
Mots clés
978-3-662-44739-0_17_Chapter.pdf (308.42 Ko) Télécharger le fichier
hal-01388232 , version 1 (26-10-2016)
Paternité
Marcelo T. Okano, Fernando S. Marins, Oduvaldo Vendrametto. How Information Systems Assist the Management of the Supply Chain in an Emerging Country Like Brazil. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2014, Ajaccio, France. pp.132-141, ⟨10.1007/978-3-662-44739-0_17⟩. ⟨hal-01388232⟩
86 Consultations
127 Téléchargements
