Mobile Personalised Support in Industrial Environments: Coupling Learning with Context - Aware Features
The human response time to events in a manufacturing environment depends both on the available skills and competencies of technical staff but also on the extent to which actionable and task-relevant content is readily available when and where is needed. Relevance itself is determined by the task situation context, which in turn is influenced by many factors. This paper presents the development of a context-aware mobile support system for personalised assistance in industrial environments. Combining the individual strengths of learning and content management systems with the ubiquity of delivering relevant content to users carrying NFC (Near Field Communication) enabled mobile devices, the system aims at both enhancing personnel competences as well as their work efficiency. The developed solution is customised to serve an industrial maintenance-support application scenario, wherein the relevant context is determined through location and asset identification, as well as through task and user profiling, offering practical on the spot mobile support.
Informatique [cs]
