Listing Acyclic Orientations of Graphs with Single and Multiple Sources - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We study enumeration problems for the acyclic orientations of an undirected graph with n nodes and m edges, where each edge must be assigned a direction so that the resulting directed graph is acyclic. When the acyclic orientations have single or multiple sources specified as input along with the graph, our algorithm is the first one to provide guaranteed bounds, giving new bounds with a delay of O(m⋅n) time per solution and O(n2) working space. When no sources are specified, our algorithm improves over previous work by reducing the delay to O(m), and is the first one with linear delay.
EnumeratingAcyclicOrientations.pdf (470.8 Ko) Télécharger le fichier
hal-01388470 , version 1 (30-05-2017)
Alessio Conte, Roberto Grossi, Andrea Marino, Romeo Rizzi. Listing Acyclic Orientations of Graphs with Single and Multiple Sources. LATIN 2016: Theoretical Informatics - 12th Latin American Symposium, Apr 2016, Ensenada, Mexico. pp.319-333, ⟨10.1007/978-3-662-49529-2_24⟩. ⟨hal-01388470⟩
Collections
INRIA INRIA2
99 Consultations
625 Téléchargements
