New interface
Journal articles
CAVE Size Matters: Effects of Screen Distance and Parallax on Distance Estimation in Large Immersive Display Setups
Gerd Bruder 1 Ferran Argelaguet Sanz 2 Anne-Héléne Olivier 3, 4 Anatole Lécuyer 2
2 Hybrid - 3D interaction with virtual environments using body and mind
Inria Rennes – Bretagne Atlantique , IRISA-D6 - MEDIA ET INTERACTIONS
4 MIMETIC - Analysis-Synthesis Approach for Virtual Human Simulation
UR2 - Université de Rennes 2, Inria Rennes – Bretagne Atlantique , IRISA-D6 - MEDIA ET INTERACTIONS
Abstract : When walking within a CAVE-like system, accommodation distance, parallax and angular resolution vary according to the distance between the user and the projection walls which can alter spatial perception. As these systems get bigger, there is a need to assess the main factors influencing spatial perception in order to better design immersive projection systems and virtual reality applications. Such analysis is key for application domains which require the user to explore virtual environments by moving through the physical interaction space. In this article we present two experiments which analyze distance perception when considering the distance towards the projection screens and parallax as main factors. Both experiments were conducted in a large immersive projection system with up to ten meter interaction space. The first experiment showed that both the screen distance and parallax have a strong asymmetric effect on distance judgments. We observed increased underestimation for positive parallax conditions and slight distance overestimation for negative and zero parallax conditions. The second experiment further analyzed the factors contributing to these effects and confirmed the observed effects of the first experiment with a high-resolution projection setup providing twice the angular resolution and improved accommodative stimuli. In conclusion, our results suggest that space is the most important characteristic for distance perception, optimally requiring about 6 to 7-meter distance around the user, and virtual objects with high demands on accurate spatial perception should be displayed at zero or negative parallax.
Document type :
Journal articles
Complete list of metadata
Cited literature [35 references]  Display  Hide  Download
https://hal.inria.fr/hal-01388499
Contributor : Ferran Argelaguet Sanz Connect in order to contact the contributor
Submitted on : Thursday, October 27, 2016 - 10:37:09 AM
Last modification on : Monday, July 25, 2022 - 3:28:23 AM
File
pre-print.pdf
Identifiers
Citation
Gerd Bruder, Ferran Argelaguet Sanz, Anne-Héléne Olivier, Anatole Lécuyer. CAVE Size Matters: Effects of Screen Distance and Parallax on Distance Estimation in Large Immersive Display Setups. Presence: Teleoperators and Virtual Environments, 2016, 25 (1), pp.1 - 16. ⟨10.1162/PRES_a_00241⟩. ⟨hal-01388499⟩
Share
Metrics
Record views
498
Files downloads
345
