Pairwise Compatibility Graphs: A Survey - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Review Année : 2016
A graph $G=(V,E)$ is a pairwise compatibility graph (PCG) if there exists an edge-weighted tree $T$ and two nonnegative real numbers $d_{min}$ and $d_{max}$ such that each leaf $u$ of $T$ is a node of $V$ and there is an edge $(u,v) \in E$ if and only if $d_{min} \leq d_T (u, v) \leq d_{max}$, where $d_T (u, v)$ is the sum of weights of the edges on the unique path from $u$ to $v$ in $T$. In this article, we survey the state of the art concerning this class of graphs and some of its subclasses.
SurveyPCG.pdf (537.67 Ko) Télécharger le fichier
hal-01388533 , version 1 (29-05-2017)
Tiziana Calamoneri, Blerina Sinaimeri. Pairwise Compatibility Graphs: A Survey. SIAM Review, 2016, 58 (3), pp.445 - 460. ⟨10.1137/140978053⟩. ⟨hal-01388533⟩
131 Consultations
715 Téléchargements
