Learning Iterative Processes with Recurrent Neural Networks to Correct Satellite Image Classification Maps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
Emmanuel Maggiori
  • Fonction : Auteur
  • PersonId : 968713
Yuliya Tarabalka
  • Fonction : Auteur
  • PersonId : 929906
Pierre Alliez
While initially devised for image categorization, convolutional neural networks (CNNs) are being increasingly used for the pixelwise semantic labeling of images. However, the proper nature of the most common CNN architectures makes them good at recognizing but poor at localizing objects precisely. This problem is magnified in the context of aerial and satellite image labeling, where a spatially fine object outlining is of paramount importance. Different iterative enhancement algorithms have been presented in the literature to progressively improve the coarse CNN outputs, seeking to sharpen object boundaries around real image edges. However, one must carefully design, choose and tune such algorithms. Instead, our goal is to directly learn the iterative process itself. For this, we formulate a generic iterative enhancement process inspired from partial differential equations, and observe that it can be expressed as a recurrent neural network (RNN). Consequently, we train such a network from manually labeled data for our enhancement task. In a series of experiments we show that our RNN effectively learns an iterative process that significantly improves the quality of satellite image classification maps.
Maggiori_RNN2016.pdf (2.99 Mo) Télécharger le fichier
hal-01388551 , version 1 (27-10-2016)
Emmanuel Maggiori, Guillaume Charpiat, Yuliya Tarabalka, Pierre Alliez. Learning Iterative Processes with Recurrent Neural Networks to Correct Satellite Image Classification Maps. 2016. ⟨hal-01388551⟩
463 Consultations
909 Téléchargements
