New interface
Conference papers
Robust Face Hallucination Using Quantization-Adaptive Dictionaries
Reuben Farrugia 1 Christine Guillemot 2
2 Sirocco - Analysis representation, compression and communication of visual data
Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : Existing face hallucination methods are optimized to super-resolve uncompressed images and are not able to handle the distortions caused by compression. This work presents a new dictionary construction method which jointly models both distortions caused by down-sampling and compression. The resulting dictionaries are then used to make three face super-resolution methods more robust to compression. Experimental results show that the proposed dictionary construction method generates dictionaries which are more representative of the low-quality face image being restored and makes the extended face hallucination methods more robust to compression. These experiments demonstrate that the proposed robust face hallucination methods can achieve Peak Signal-to-Noise Ratio (PSNR) gains between 2–4.48dB and recognition improvement between 2.9–8.1% compared with the low-quality image and outperforming traditional super-resolution methods in most cases.
Document type :
Conference papers
Complete list of metadata
Cited literature [23 references]  Display  Hide  Download
https://hal.inria.fr/hal-01388972
Contributor : Christine Guillemot Connect in order to contact the contributor
Submitted on : Tuesday, November 15, 2016 - 1:30:52 PM
Last modification on : Monday, June 27, 2022 - 3:02:32 AM
Long-term archiving on: : Thursday, March 16, 2017 - 4:42:25 PM
File
camera_UPLOAD_1551.pdf
Identifiers
  • HAL Id : hal-01388972, version 1
Citation
Reuben Farrugia, Christine Guillemot. Robust Face Hallucination Using Quantization-Adaptive Dictionaries. IEEE International Conference on Image Processing, Sep 2016, Phoenix, United States. pp.5. ⟨hal-01388972⟩
Share
Metrics
Record views
215
Files downloads
126
