Abstract : Agents intending to be involved in joint operations need to rely on trust measures pointing to possible future solid partnerships. Using Multi-Agent Systems (MAS) as a paradigm for an electronic institution framework enables both to simulate and facilitate the process of autonomous agents, as either enterprises or individual representatives, reaching joint agreements through automatic negotiation. In the heart of the MAS-based electronic institution framework, a Normative Environment provides monitoring capabilities and enforcement mechanisms influencing agents’ behavior during joint activity. Moreover, it makes available relevant data that can be important for building up contextual-dependent agent’s trust models which, consequently, also influence future possible negotiations leading to new and safer agreements. To support agents data generation and monitoring, we here present ANTE platform, a software MAS integrating Trust models with negotiation facilities and Normative environments, for the creation and monitoring of agent-based networks.
https://hal.inria.fr/hal-01391312
Contributor : Hal Ifip <>
Submitted on : Thursday, November 3, 2016 - 10:56:32 AM Last modification on : Sunday, November 15, 2020 - 7:30:03 PM Long-term archiving on: : Saturday, February 4, 2017 - 12:53:01 PM
Eugénio Oliveira, Henrique Cardoso, Maria Urbano, Ana Rocha. Normative Monitoring of Agents to Build Trust in an Environment for B2B. 10th IFIP International Conference on Artificial Intelligence Applications and Innovations (AIAI), Sep 2014, Rhodes, Greece. pp.172-181, ⟨10.1007/978-3-662-44654-6_17⟩. ⟨hal-01391312⟩
