Reports
Dynamic Reconfiguration of Feature Models: an Algorithm and its Evaluation
Sabine Moisan 1 Jean-Paul Rigault 1
1 STARS - Spatio-Temporal Activity Recognition Systems
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : This paper deals with dynamic adaption of software architecture in response to context changes. In the line of “models at run time”, we keep a model of the system and its context in parallel with the running system itself. We adopted an enriched Feature Model approach to express the variability of the architecture as well as of the context. A context change is transformed into a set of feature modifications (selection/deselection) that we validate against the feature model to yield a new suitable and valid architecture configuration. Then we update the model view of the configuration and the running system architecture accordingly. The paper focuses on the feature model reconfiguration step and details the algorithms and heuristics that implement our adaptation rules. The approach is illustrated with a simple example borrowed from the videosurveillance domain. The efficiency of the algorithm is evaluated on randomly generated feature models (from 60 to 1400 features). Our results show that in our target applications (video analysis), the processing time of a context change may be considered negligible.
Document type :
Reports
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/hal-01392796
Contributor : Sabine Moisan Connect in order to contact the contributor
Submitted on : Friday, November 4, 2016 - 5:17:47 PM
Last modification on : Saturday, June 25, 2022 - 11:23:58 PM
Long-term archiving on: : Sunday, February 5, 2017 - 2:33:40 PM
File
RR-8972.pdf
Identifiers
  • HAL Id : hal-01392796, version 1
Collections
Citation
Sabine Moisan, Jean-Paul Rigault. Dynamic Reconfiguration of Feature Models: an Algorithm and its Evaluation. [Research Report] RR-8972, INRIA Sophia Antipolis. 2016, pp.16. ⟨hal-01392796⟩
Share
Metrics
Record views
144
Files downloads
104
