From Drawing to Animation-ready Vector Graphics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2016
We present an automatic method to build a layered vector graphics structure ready for animation from a clean-line vector drawing of an organic, smooth shape. Inspiring from 3D segmentation methods, we introduce a new metric computed on the medial axis of a region to identify and quantify the visual salience of a sub-region relative to the rest. This enables us to recursively separate each region into two closed sub-regions at the location of the most salient junction. The resulting structure, layered in depth, can be used to pose and animate the drawing using a regular 2D skeleton.
poster_final_HAL.pdf (990.76 Ko) Télécharger le fichier
a52-entem.pdf (130.5 Ko) Télécharger le fichier
hal-01395321 , version 1 (10-11-2016)
Even Entem, Loic Barthe, Marie-Paule Cani, Michiel van de Panne. From Drawing to Animation-ready Vector Graphics. ACM. SIGGRAPH '16, Jul 2016, Anaheim, California, United States. 52, pp.2, ACM SIGGRAPH 2016 Posters. ⟨10.1145/2945078.2945130⟩. ⟨hal-01395321⟩
596 Consultations
425 Téléchargements
