Haztrailz: Exploratory Analysis of Trajectory and Sensor Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2016
The mini challenge 2 from VAST 2016 dealt with understanding the operations data from GAStech, a fictional company. We analyzed two weeks of this data including, (1) employee locations collected using proximity cards, and (2) sensor data containing temperatures, heating and cooling status, and chemical concentration levels. Our approach involved data cleaning and consolidation using R, the development of a custom trajectory visualization tool for the analysis of location data, as well as the use of existing analysis tools for the combined analysis of sensor and location data. In this paper, we discuss our analysis process, and report patterns and anomalies, as well as suspicious activities identified within the building.
haztrailz.pdf (1.03 Mo) Télécharger le fichier
Format : Figure, Image
hal-01397007 , version 1 (18-11-2016)
  • HAL Id : hal-01397007 , version 1
Sriram Karthik Badam, Christoph Kinkeldey, Petra Isenberg. Haztrailz: Exploratory Analysis of Trajectory and Sensor Data: VAST 2016 Mini Challenge 2 Award: Honorable Mention for Clear Analysis Strategy. IEEE Visual Analytics Science and Technology, VAST Challenge, Nov 2016, Los Alamitos, CA, United States. ⟨hal-01397007⟩
443 Consultations
181 Téléchargements
