Abstract : This work explores scheduling challenges in providing prob-abilistic Byzantine fault tolerance in a hybrid cloud environment , consisting of nodes with varying reliability levels, compute power, and monetary cost. In this context, the probabilistic Byzantine fault tolerance guarantee refers to the confidence level that the result of a given computation is correct despite potential Byzantine failures. We formally define a family of such scheduling problems distinguished by whether they insist on meeting a given latency limit and trying to optimize the monetary budget or vice versa. For the case where the latency bound is a restriction and the budget should be optimized, we present several heuristic protocols and compare between them using extensive simulations.
