A Software-Defined Security Strategy for Supporting Autonomic Security Enforcement in Distributed Cloud - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose in this paper a software-defined security framework, for supporting the enforcement of security policies in distributed cloud environments. These ones require security mechanisms able to cope with their multi-tenancy and multi-cloud properties. This framework relies on the autonomic paradigm to dynamically configure and adjust these mechanisms to distributed cloud constraints, and exploit the software-defined logic to express and propagate security policies to the considered cloud resources. The proposed framework is evaluated through a set of validation scenarios corresponding to a realistic use cases including cloud resource allocation/deallocation, cloud resource state change, and dynamic access control.
PositionPaper-Draft.pdf (972.33 Ko) Télécharger le fichier
hal-01399458 , version 1 (03-08-2018)
Maxime Compastié, Rémi Badonnel, Olivier Festor, Ruan He, Mohamed Kassi-Lahlou. A Software-Defined Security Strategy for Supporting Autonomic Security Enforcement in Distributed Cloud. CloudCom 2016 - IEEE International Conference on Cloud Computing Technology and Science, Dec 2016, Luxembourg, Luxembourg. pp.4, ⟨10.1109/CloudCom.2016.0079⟩. ⟨hal-01399458⟩
378 Consultations
312 Téléchargements
