Journal articles
Damage detection in a post tensioned concrete beam – Experimental investigation
Abstract : The paper deals with the results of an experimental campaign carried out on a post tensioned concrete beam with the aim of investigating the possibility to detect early warning signs of deterioration based on static and/or dynamic tests. The beam was tested in several configurations aimed to reproduce 5 different phases of the ‘life‘ of the beam: in the original undamaged state, un-der increasing loss of tension in the post tensioning cables, during and after the formation of cracks at mid span, after a strengthening intervention carried out by means of a second tension cable, dur-ing and after the formation of further cracks on the strengthened beam. Responses of the beam were measured by an extensive set of instruments consisting of accelerometers, inclinometers, displace-ment transducers, strain gauges and optical fibers. In this paper data from accelerometers and dis-placement transducers have been exploited. The paper presents the test program and the dynamic characterization of the beam in the different damage scenarios in terms of the first modal frequency, identified from dynamic tests and of the bending stiffness monitored during static tests.
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/hal-01400881
Contributor : Laurent Mevel Connect in order to contact the contributor
Submitted on : Friday, December 16, 2016 - 11:31:29 AM
Last modification on : Friday, July 8, 2022 - 10:05:07 AM
File
manuscript_rev_final_mp.pdf
Identifiers
Collections
Citation
Maria Pina Limongelli, Dominique Siegert, Erick Merliot, Julien Waeytens, Frédéric Bourquin, et al.. Damage detection in a post tensioned concrete beam – Experimental investigation. Engineering Structures, Elsevier, 2016, 128, pp.15 - 25. ⟨10.1016/j.engstruct.2016.09.017⟩. ⟨hal-01400881⟩
Share
Metrics
Record views
382
Files downloads
415
