A Pre-processing Composition for Secret Key Recovery on Android Smartphone - Archive ouverte HAL Access content directly
Conference Papers Year : 2014
(1) , (2) , (2) , (2) , (2) , (2) , (1) , (1)
1
2
Yuto Nakano
  • Function : Author
  • PersonId : 993988
Youssef Souissi
  • Function : Author
  • PersonId : 971834
Robert Nguyen
  • Function : Author
  • PersonId : 925649
Laurent Sauvage
Jean-Luc Danger
Sylvain Guilley
Shinsaku Kiyomoto
  • Function : Author
  • PersonId : 990575
Yutaka Miyake
  • Function : Author
  • PersonId : 990576
Simple Side-Channel Analyses (SSCA) are known as techniques to uncover a cryptographic secret from one single spied waveform. Up to now, these very powerful attacks have been illustrated on simple devices which leakage was obvious. On more advanced targets, such as high-end processors of smartphones, a simple visual analysis of the waveforms might not be sufficient to read the secret at once. In this paper, we detail and explain how a composition of time-frequency pre-processings manages to extract the relevant information from one signal capture of an asymmetric cryptographic operation (RSA and ECC) running on an Android system. The lesson is that side-channel countermeasures must be applied even on advanced platforms such as smartphones to prevent secret information theft through the electromagnetic (EM) waveforms.
978-3-662-43826-8_6_Chapter.pdf (1.45 Mo) Télécharger le fichier
Dates and versions
hal-01400921 , version 1 (22-11-2016)
Attribution - CC BY 4.0
Identifiers
Cite
Yuto Nakano, Youssef Souissi, Robert Nguyen, Laurent Sauvage, Jean-Luc Danger, et al.. A Pre-processing Composition for Secret Key Recovery on Android Smartphone. 8th IFIP International Workshop on Information Security Theory and Practice (WISTP), Jun 2014, Heraklion, Crete, Greece. pp.76-91, ⟨10.1007/978-3-662-43826-8_6⟩. ⟨hal-01400921⟩
156 View
302 Download
Share
