CAN Bus Risk Analysis Revisit - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hafizah Mansor
  • Fonction : Auteur
  • PersonId : 994011
Keith Mayes
  • Fonction : Auteur
  • PersonId : 994013
In automotive design process, safety has always been the main concern. However, in modern days, security is also seen as an important aspect in vehicle communication especially where connectivity is very widely available. In this paper, we are going to discuss the threats and vulnerabilities of a CAN bus network. After we have considered a number of risk analysis methods, we decided to use FMEA. The analysis process allowed us to derive the security requirements of a CAN bus. Experimental setup of CAN bus communication network were implemented and analysed.
978-3-662-43826-8_13_Chapter.pdf (191.26 Ko) Télécharger le fichier
hal-01400939 , version 1 (22-11-2016)
Paternité
Hafizah Mansor, Konstantinos Markantonakis, Keith Mayes. CAN Bus Risk Analysis Revisit. 8th IFIP International Workshop on Information Security Theory and Practice (WISTP), Jun 2014, Heraklion, Crete, Greece. pp.170-179, ⟨10.1007/978-3-662-43826-8_13⟩. ⟨hal-01400939⟩
177 Consultations
1484 Téléchargements
