A Ontology-based Approach for Business Process Compliance Checking
The early detection of flaws and errors has become a significant feature of a business process modeling tool. This paper proposes an ontology-based approach for business process compliance checking. The business processes and the business rules are represented in a machine understandable form, a reasoner is used to reason on this knowledge base for detecting the potential semantic error by using a set of predefined rules.
