Does Aligning Phenotypic and Genotypic Modularity Improve the Evolution of Neural Networks? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Joost Huizinga
  • Fonction : Auteur
  • PersonId : 994247
Jeff Clune
  • Fonction : Auteur
  • PersonId : 965457
Many argue that to evolve artificial intelligence that rivals that of natural animals, we need to evolve neural networks that are structurally organized in that they exhibit modularity, regularity, and hierarchy. It was recently shown that a cost for network connections, which encourages the evolution of modularity, can be combined with an indirect encoding , which encourages the evolution of regularity, to evolve networks that are both modular and regular. However, the bias towards regularity from indirect encodings may prevent evolution from independently optimizing di↵erent modules to perform different functions, unless modularity in the phenotype is aligned with modularity in the genotype. We test this hypothesis on two multi-modal problems—a pattern recognition task and a robotics task—that each require di↵erent phenotypic modules. In general, we find that performance is improved only when genotypic and phenotypic modularity are encouraged simultaneously, though the role of alignment remains unclear. In addition, intuitive manual decompositions fail to provide the performance benefits of automatic methods on the more challenging robotics problem , emphasizing the importance of automatic, rather than manual, decomposition methods. These results suggest encouraging modularity in both the genotype and phenotype as an important step towards solving large-scale multi-modal problems, but also indicate that more research is required before we can evolve structurally organized networks to solve tasks that require multiple, different neural modules.
StructuralOrganizationRobotics.pdf (6.02 Mo) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-01402502 , version 1 (25-11-2016)
Joost Huizinga, Jean-Baptiste Mouret, Jeff Clune. Does Aligning Phenotypic and Genotypic Modularity Improve the Evolution of Neural Networks?. Proceedings of the 25th Genetic and Evolutionary Computation Conference (GECCO), ACM, 2016, Denver, France. pp.125 - 132, ⟨10.1145/2908812.2908836⟩. ⟨hal-01402502⟩
148 Consultations
172 Téléchargements
