Impedance Transmission Conditions for the Electric Potential across a Highly Conductive Casing
Borehole resistivity measurements are a common procedure when trying to obtain
a better characterization of the Earth’s subsurface. The possible risk of having borehole col-
lapses makes the employment of a casing very suitable for this type of scenarios. Such casing
protects the borehole but it also highly complicates the numerical analysis due to its thinness
and large contrast between the conductivities of the casing and the rock formations.
In this work, motivated by realistic configurations, we consider the conductivity of the casing
to have the form σ c ≈ ε −3 when ε denotes the thickness of the casing. In this framework, our
aim is to derive Impedance Transmission Conditions (ITCs) for the electromagnetic field across
such a casing. As a first approach we derive ITCs for the electric potential.
In this work, we consider a transmission problem for the static case of the electric potential
(u), div (σ∇u) = f , set in an axisymmetric borehole shaped domain. This domain is composed of three different subdomains, the interior part of the borehole, the rock formations and the metallic casing. Here σ represents the conductivity and f represents the right hand side.
In this framework we address the issue of ITCs for u (as ε → 0) using two different ap-
proaches. The first one consists in deriving ITCs across the casing itself, whereas the second
approach tackles the problem by deriving ITCs on an artificial interface located in the middle
of the casing.
We derive different models for the two considered approaches and we numerically
assess them with a finite element method implementation. Then we perform a comparison on
these models by showing the advantages and drawbacks of each model. Finally, we show an
application to a borehole through-casing resistivity measurement scenario. This work delivers
both existence and uniqueness proofs, along with stability results and error estimates, lead-
ing to convergence of each approximate model
