Homogeneity of differential inclusions
In this chapter the notion of geometric homogeneity is extended for differential inclusions. This kind of homogeneity provides the most advanced coordinate-free framework for analysis and synthesis of nonlinear discontinuous systems. The main qualitative properties of continuous homogeneous systems are extended to the discontin-uous setting: the equivalence of the global asymptotic stability and the existence of a homogeneous Lyapunov function; the link between finite-time stability and negative degree of homogeneity; the equivalence between attractivity and asymptotic stability are among the proved results.
Automatique
