Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : Advanced industrial robots are composed of several independent control systems. Particularly, robots that perform process-intensive tasks such as painting, gluing, and sealing have dedicated process control systems that are more or less loosely coupled with the motion control system. Validating software for such robotic systems is challenging. A major reason for this is that testing the software for such systems requires access to physical systems to test many of their characteristics.In this paper, we present a method, developed at ABB Robotics in collaboration with SIMULA, for automated testing of such process control systems. Our approach draws on previous work from continuous integration and the use of well-established constraint-based testing and optimization techniques. We present a constraint-based model for automatically generating test sequences where we both generate and execute the tests as part of a continuous integration process. We also present results from a pilot installation at ABB Robotic where ABB’s Integrated Process Control system has been tested. The results show that the model is both able to discover completely new errors and to detect old reintroduced errors. From this experience, we report on lessons learned from implementing an automatic test generation and execution process for a distributed control system for industrial robots.
https://hal.inria.fr/hal-01405281 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, November 29, 2016 - 4:41:19 PM Last modification on : Thursday, October 3, 2019 - 3:36:02 PM Long-term archiving on: : Monday, March 27, 2017 - 8:26:59 AM
Morten Mossige, Arnaud Gotlieb, Hein Meling. Testing Robotized Paint System Using Constraint Programming: An Industrial Case Study. 26th IFIP International Conference on Testing Software and Systems (ICTSS), Sep 2014, Madrid, Spain. pp.145-160, ⟨10.1007/978-3-662-44857-1_10⟩. ⟨hal-01405281⟩
