New interface
Conference papers
Wavelength spacing optimization to reduce crosstalk in WDM 3D ONoC
Abstract : Due to the increased bandwidth and decreased latency, Optical Network-on-Chip (ONoC) is a good solution for interconnect bottleneck in large-scale Multiprocessor System on Chip (MPSoC). It takes advantage of Wavelength Division Multiplexing (WDM) supporting multiple transactions at same time on different wavelengths. Hence, many senders and receivers can share the same waveguide to increase the total bandwidth utilization. However, multiple overlapped communications on different (close) wavelengths would inevitably introduce non-negligible crosstalk noise on optical signals in large-scale WDM 3D ONoC due to the low wavelength channel spacing and the large Full Width at Half Maximum (FWHM) of the resonance pic of the Microring Resonator (MR). This paper proposes a heuristic algorithm allowing to allocate wavelengths at design time in order to reduce the crosstalk noise. The simulation results show that the proposed heuristic algorithm achieves the same Wavelength Spacing Optimization (WSO) as that of Branch and Bound algorithm for MWD application, 43.75% reduction compared to naive method [10] .
Complete list of metadata
https://hal.inria.fr/hal-01406341
Contributor : Daniel Chillet Connect in order to contact the contributor
Submitted on : Thursday, December 1, 2016 - 9:51:25 AM
Last modification on : Wednesday, February 2, 2022 - 3:57:46 PM
Long-term archiving on: : Tuesday, March 21, 2017 - 8:26:17 AM
File
compas2016_luo.pdf
Identifiers
  • HAL Id : hal-01406341, version 1
Citation
Jiating Luo, Daniel Chillet, Cédric Killian, Sébastien Le Beux, Ian O 'Connor, et al.. Wavelength spacing optimization to reduce crosstalk in WDM 3D ONoC. Conférence d’informatique en Parallélisme, Architecture et Système, Jul 2016, Lorient, France. ⟨hal-01406341⟩
Share
Metrics
Record views
450
Files downloads
96
