Quantifying White Matter Microstructure with a Unified Spatio-Temporal Diffusion Weighted MRI Continuous Representation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A current problem Diffusion MRI (dMRI) based microscopy under the narrow pulse approximation is how to best exploit the 4D (q-space + diffusion time) nature of the signal. Assaf et al. showed that exploring the dMRI attenuation at different diffusion times provides information on the distribution of axonal diameters within a voxel in their seminal work: AxCaliber. However, AxCaliber requires knowing beforehand the predominant orientation of the axons within the analyzed volume to adjust the q-space sampling accordingly. In this work, we show that our novel sparse representation of the 3D+t dMRI signal, enables the recovery of axonal diameter distribution parameters without the need to know the axonal direction at acquisition time.
Fichier non déposé
hal-01406348 , version 1 (01-12-2016)
  • HAL Id : hal-01406348 , version 1
Demian Wassermann, Alexandra Petiet, Mathieu Santin, Rutger H.J. Fick, Anne-Charlotte Philippe, et al.. Quantifying White Matter Microstructure with a Unified Spatio-Temporal Diffusion Weighted MRI Continuous Representation. International Symposium of Magnetic Resonance in Medicine, 2016, Singapore, Singapore. ⟨hal-01406348⟩
284 Consultations
0 Téléchargements
