Low CD4/CD8 Ratio Is Associated with Non AIDS-Defining Cancers in Patients on Antiretroviral Therapy: ANRS CO8 (Aproco/Copilote) Prospective Cohort Study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue PLoS ONE Année : 2016
Objectives To study the association between CD4/CD8 ratio and morbidity in HIV-infected patients on antiretroviral therapy (ART). Methods The APROCO/COPILOTE cohort enrolled patients initiating a protease inhibitor-containing ART in 1997-1999. The association between occurrence of first non AIDS-defining severe events (NADE) and time-dependent measures of immune restoration was assessed by 4 Cox models with different definitions of restoration, CD4+ cell counts (CD4), CD4/CD8 ratio, both CD4 and CD4/CD8 ratio, or a composite variable (CD4< 500/mm 3 , CD4 > 500/mm 3 and CD4/CD8 ratio < 1, CD4 > 500/mm 3 and CD4/CD8 ratio > 1). Models adjusted on base-line characteristics and time-dependent viral load were compared using Akaike Information Criterion. Methods: The APROCO/COPILOTE cohort enrolled patients initiating a protease inhibitor-containing ART in 1997–1999. The association between occurrence of first non AIDS-defining severe events (NADE) and time-dependent measures of immune restoration was assessed by 4 Cox models with different definitions of restoration, CD4+ cell counts (CD4), CD4/CD8 ratio, both CD4 and CD4/CD8 ratio, or a composite variable (CD4< 500/mm3, CD4 > 500/mm3 and CD4/CD8 ratio < 1, CD4 > 500/mm3 and CD4/CD8 ratio > 1). Models adjusted on baseline characteristics and time-dependent viral load were compared using Akaike Information Criterion. Results: We included 1227 patients. Median duration of follow-up was 9.2 years (IQR: 4.2–11.4). Median CD4 was 530/mm3 at 9 years. Median CD4/CD8 ratio was 0.3 (IQR: 0.2–0.5) at baseline and 0.6 (IQR: 0.4–0.9) after 9 years. Incidence of first NADE was 7.4/100 person-years, the most common being bacterial infections (21%), cardiovascular events (14%) and cancers (10%). For both bacterial infections and cardiovascular events, the CD4/CD8 ratio did not add predictive information to the CD4 cell count. However, low CD4/CD8 ratio was the best predictor of non-AIDS cancers (adjusted HR = 2.13 for CD4/CD8 < 0.5; 95% CI = 1.32–3.44). Conclusions: CD4/CD8 ratio remains < 1 in most HIV-infected patients despite long-term CD4+ cell counts restoration on ART. A CD4/CD8 ratio < 0.5 could identify patients who require a more intensive strategy of cancer prevention or screening.
journal.pone.0161594(1).PDF (192.95 Ko) Télécharger le fichier
Origine : Publication financée par une institution
hal-01406618 , version 1 (14-12-2018)
Paternité
Mariam Noelie Hema, Tristan Ferry, Michel Dupon, Lise Cuzin, Renaud Verdon, et al.. Low CD4/CD8 Ratio Is Associated with Non AIDS-Defining Cancers in Patients on Antiretroviral Therapy: ANRS CO8 (Aproco/Copilote) Prospective Cohort Study. PLoS ONE, 2016, 11 (8), pp.e0161594. ⟨10.1371/journal.pone.0161594⟩. ⟨hal-01406618⟩
379 Consultations
469 Téléchargements
