Extensible Modules for JavaScript - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2016
The module pattern in JavaScript is commonly used to encapsulate definitions by using closures. However, closures prevent module definitions from being extended at runtime. We propose a simple pattern that not only opens the module, but allows one to extend the module definitions in layers. The pattern leverages the with construct and the prototype delegation mechanism of JavaScript to mimick dynamic binding, while minimizing the changes made to the module code.
Fichier non déposé
hal-01407340 , version 1 (01-12-2016)
Florent Marchand de Kerchove, Jacques Noyé, Mario Südholt. Extensible Modules for JavaScript. ACM Press. SAC '16 - 31st Annual ACM Symposium on Applied Computing, Apr 2016, Pisa, Italy. , Proceedings of the 31st Annual ACM Symposium on Applied Computing, pp.3, 2016, ⟨10.1145/2851613.2851958⟩. ⟨hal-01407340⟩
269 Consultations
0 Téléchargements
