Unveiling the Dispersion Kernel in DSC-MRI by Means of Dispersion-Compliant Bases and Control Point Interpolation Techniques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In DSC-MRI the presence of dispersion affects the estimation, via deconvolution, of the residue function that characterizes the perfusion in each voxel. Dispersion is descibed by a Vascular Transport Function (VTF) which knolewdge is essential to recover a dispersion-free residue function. State-of-the-art techniques aim at characterizing the VTF but assume a specific shape for it, which in reality is unknown. We propose to estimate the residue function without assumptions by means of Dispersion-Compliant Bases (DCB). We use these results to find which VTF model better describes the in vivo data for each tissue type by means of control point interpolation approaches.
Pizzolato_et_al_ISMRM_abstract_0649_2016.pdf (806.77 Ko) Télécharger le fichier
hal-01408170 , version 1 (03-12-2016)
  • HAL Id : hal-01408170 , version 1
Marco Pizzolato, Rutger H.J. Fick, Timothé Boutelier, Rachid Deriche. Unveiling the Dispersion Kernel in DSC-MRI by Means of Dispersion-Compliant Bases and Control Point Interpolation Techniques. ISMRM 24th Annual Meeting, May 2016, Singapore, Singapore. ⟨hal-01408170⟩
238 Consultations
74 Téléchargements
