Abstract : The combinatorial stochastic semi-bandit problem is an extension of the classical multi-armed bandit problem in which an algorithm pulls more than one arm at each stage and the rewards of all pulled arms are revealed. One difference with the single arm variant is that the dependency structure of the arms is crucial. Previous works on this setting either used a worst-case approach or imposed independence of the arms. We introduce a way to quantify the dependency structure of the problem and design an algorithm that adapts to it. The algorithm is based on linear regression and the analysis develops techniques from the linear bandit literature. By comparing its performance to a new lower bound, we prove that it is optimal, up to a poly-logarithmic factor in the number of pulled arms.
https://hal.inria.fr/hal-01408534 Contributor : Vianney PerchetConnect in order to contact the contributor Submitted on : Monday, December 5, 2016 - 9:55:11 AM Last modification on : Wednesday, November 3, 2021 - 6:17:27 AM Long-term archiving on: : Tuesday, March 21, 2017 - 6:47:57 AM
Rémy Degenne, Vianney Perchet. Combinatorial semi-bandit with known covariance. NIPS 2016 (Conference on Neural Information Processing Systems), Dec 2016, Barcelona, Spain. ⟨hal-01408534⟩
