Hyperspectral Image Processing for Detection and Grading of Skin Erythema - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Visual assessment is the most common clinical investigation of skin reactions in radiotherapy. Due to the subjective nature of this method, additional noninvasive techniques are needed for more accurate evaluation. Our goal is to evaluate the effectiveness of hyperspectral image analysis for that purpose. In this pilot study, we focused on detection and grading of skin Erythema. This paper reports our proposed processing pipeline and experimental findings. Experiments have been performed to demonstrate the efficacy of the proposed approach for (1) reproducing clinical assessments, and (2) outperforming RGB imaging data.
spie_final.pdf (886.34 Ko) Télécharger le fichier
hal-01408854 , version 1 (05-12-2016)
hal-01408854 , version 2 (13-12-2016)
  • HAL Id : hal-01408854 , version 2
Ali Madooei, Ramy Mohammed Abdlaty, Lilian S Doerwald-Munoz, Joseph S Hayward, Mark S Drew, et al.. Hyperspectral Image Processing for Detection and Grading of Skin Erythema. SPIE Medical Imaging, Feb 2017, Orlando, Florida, United States. ⟨hal-01408854v2⟩
Collections
INRIA INRIA2
242 Consultations
491 Téléchargements
