Travelling waves in a spring-block chain sliding down a slope - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2016
Travelling waves in a spring-block chain sliding down an inclined plane are studied. For a piecewise-linear spinodal friction force, we construct analytically front waves. Pulse waves are obtained as the matching of two travelling fronts with identical speeds. Explicit formulas are obtained for the wavespeed and the wave form in the anti-continuum limit. The link with propagating phenomena in the Burridge-Knopoff model is briefly discussed.
RR-8995.pdf (902.75 Ko) Télécharger le fichier
hal-01411516 , version 1 (07-12-2016)
  • HAL Id : hal-01411516 , version 1
José Eduardo Morales Morales, Guillaume James, Arnaud Tonnelier. Travelling waves in a spring-block chain sliding down a slope. [Research Report] RR-8995, INRIA Grenoble - Rhône-Alpes. 2016. ⟨hal-01411516⟩
194 Consultations
215 Téléchargements
