Permutations via linear translators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Finite Fields and Their Applications Année : 2017
We show that many infinite classes of permutations over finite fields can be constructed via translators with a large choice of parameters. We first characterize some functions having linear translators, based on which several families of permutations are then derived. Extending the results of \cite{kyu}, we give in several cases the compositional inverse of these permutations. The connection with complete permutations is also utilized to provide further infinite classes of permutations. Moreover, we propose new tools to study permutations of the form $x\mapsto x+(x^{p^m}-x+\delta)^s$ and a few infinite classes of permutations of this form are proposed.
translator_main_FFA_Final_Nov12_V2.pdf (131.83 Ko) Télécharger le fichier
hal-01412487 , version 1 (08-12-2016)
hal-01412487 , version 2 (12-12-2016)
Nastja Cepak, Pascale Charpin, Enes Pasalic. Permutations via linear translators. Finite Fields and Their Applications, 2017, 45, pp.19--42. ⟨10.1016/j.ffa.2016.11.009⟩. ⟨hal-01412487v2⟩
Collections
INRIA INRIA2
242 Consultations
190 Téléchargements
