Hybrid simulation of high-Reynolds number flows relying on a variational multiscale model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We are interested in the study and improvement of the LES component in hybrid RANS-LES formulations. These models are not designed for blunt-body flows with laminar boundary layers, but it is interesting to examine how they behave in that case. A DDES model is compared with a dynamic Variational multi-scale (DVMS) LES model for two subcritical flows past a cylinder. We then propose a hybridation restricting to DVMS in LES regions. The performances of the different options are compared for subcritical flows and for a flow around a tandem cylinder.
Itam-HRLM6-Full-paper-LAST.pdf (422.81 Ko) Télécharger le fichier
hal-01413453 , version 1 (09-12-2016)
  • HAL Id : hal-01413453 , version 1
Emmanuelle Itam, Stephen Wornom, Bruno Koobus, Alain Dervieux. Hybrid simulation of high-Reynolds number flows relying on a variational multiscale model. 6th Symposium on Hybrid RANS-LES Methods , Sep 2016, Strasbourg, France. ⟨hal-01413453⟩
128 Consultations
159 Téléchargements
