Adaptive Optimal Stochastic Control of Delay--Tolerant Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Mobile Computing Année : 2016
Optimal stochastic control of delay tolerant networks is studied in this paper. First, the structure of optimal two-hop forwarding policies is derived. In order to be implemented, such policies require knowledge of certain global system parameters such as the number of mobiles or the rate of contacts between mobiles. But, such parameters could be unknown at system design time or may even change over time. In order to address this problem, adaptive policies are designed that combine estimation and control: based on stochastic approximation techniques, such policies are proved to achieve optimal performance in spite of lack of global information. Furthermore, the paper studies interactions that may occur in the presence of several DTNs which compete for the access to a gateway node. The latter problem is formulated as a cost-coupled stochastic game and a unique Nash equilibrium is found. Such equilibrium corresponds to the system configuration in which each DTN adopts the optimal forwarding policy determined for the single network problem.
StochApprox_TMC_R2.pdf (376.63 Ko) Télécharger le fichier
hal-01414802 , version 1 (12-12-2016)
Eitan Altman, Francesco de Pellegrini, Daniele Miorandi, Giovanni Neglia. Adaptive Optimal Stochastic Control of Delay--Tolerant Networks. IEEE Transactions on Mobile Computing, 2016, pp.1 - 15. ⟨10.1109/TMC.2016.2611507⟩. ⟨hal-01414802⟩
Collections
INRIA INRIA2
94 Consultations
234 Téléchargements
